Thread: LED Floodlights - Not in Pool
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I'm currently using 2 500W halogen floodlights to illuminate the backyard around the patio & pool. These are the typical lights you can buy at HD for $30 or so. One's mounted on the house, the other on the shed. I use them a lot, so I'd like to find a solution that uses a bit less electricity.
    Has anyone found an LED option that gives as much light as a 500W, or maybe a 300W, halogen flood? I've seen some online that might work, but they're pricey, so I'd like get some user feedback before spending the $$.
    Thanks!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    4knights's Avatar
    NE Kansas
    419
    Re: LED Floodlights - Not in Pool
    We bought 2 LED Flood lights at HomeDepot-$35.00 each. We replaced the 300watt flood lights in the drive and over the garage. They are on a motion sensor and the rabbits, deer, cats, fox, coyotes all make sure they stay on pretty much 24/7. We have had them for 4 months so far and they are more than bright enough to light up the area.
    Well worth the money and the utility bill actually decreased. They won't give you stadium lighting effect if that's what you're looking for but are very bright.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    not sure if you can find a 500w replacement but RAB lighting makes a 78w led that replaces a 250w and they make a pretty good product. im in electrical sales but dont do much lighting, leds are still in there infancy, there seems to be changes every week i'm holding off on going leds for awhile. you have to look at the lamp life on what ever floodlight your looking at, going off the top of my head Rabs led flood has a 100000hr life and a standard quartz bulb life might be 10000hrs at most. so buying 10 halogen bulbs should justify the cost. you can go online ane find a calculator on electic use but right now has rule it led use 1/3 of the energy so if you calculate it over the life of the bulb it makes sense. it's one of those those things that seems like your spending alot of money but in the long run you save money
    32000 gal , gunite pool, de filter weber gensis and tiki bar
    Jul 2013
    Waxahachie, Tx.
    446
    http://www.larsonelectronics.com/c-561- ... ights.aspx
    Try that link they have a ton of difernet types. We use a lot from them where I work.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    I have been very happy with these;
    http://www.amazon.com/Feit-Electric-Dim ... led+par+38
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
