Re: New spa, want to use bromine. What chemicals to have on
EDIT, sorry just redead your first post.
did you add 2 oz of 100% bromide granules and then actiivate it with bleach or brominating granules witch is bromide and chlorine mixed together?
the ozonator isn't going to keep your bromine level up by it's self, mine doesn't even without using the spa. so i switch to the 3 step. you will have to add bromine granules, bleach, granular chlorine, or mps to convert bromide to bromine every day with a 2 step system. after you use the tub you have to add more stuff to convert bromide to bromine. runs the jets for a min of 10 minutes "i do 20 minutes" then leave it uncovered for min 20 minutes to let it gas out so your cover last longer. hope that helps, i've just been using bromine for the last 4 months so i'm still new to this.
your water looks good, i wish i had water like that from the tap. you'll know in a few days/weeks what you will need. i didn't do the two stage long enough to know how is efects the ph and alk.
i do the 3 stage and take out the floater when we use it. i have a 400 gal tub with a ozonator.
i have 1 tab in the floater
i have to adjust the alk and ph every few days becasue the tabs i have are acidic. if alk is below 70 i add 1 tbsp ph up "aka baking soda" to raise alk and ph. if alk is 70+ i add soda ash or borax to raise ph.
i use 1 tps of granular chlorine, bromine granules or 2 tps mps for every 20-30 minutes of soak time per person.
