Page 4 of 11 FirstFirst 1234567 ... LastLast
Results 61 to 80 of 216
Thread: New AquaBot Rapids XLS and 4WD
  1. Back To Top    #61
    Jul 2007
    Chicago, IL
    87
    Re: New AquaBot Rapids XLS and 4WD
    I have the AWD Breeze and it can climb my walls to the waterline, so I'm not sure what they mean by 60%.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
  2. Back To Top    #62
    tcat's Avatar
    May 2012
    Austin, TX
    720
    And the Breeze XLS:
    For Above-Ground &*In-Ground Pools
    Pool to Wall Transition: Curved
    Power Consumption: 180 Watts
    Cable Length: 60'
    Fixed Scrubbing Brushes
    Floor, Wall, and Waterline
    6800 sq. ft. per hour
    Never Stuck System
    1 & 2 hour timer settings
    Water Mixing Capability: 85 Gallons per Minute
    Filter Type: Basket Top Loading
    Warranty: 2 Years, 1st year 100%,
    2nd year limited
    It's the one I'm getting.
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
  3. Back To Top    #63
    May 2013
    Hollister, California
    8
    Quote Originally Posted by Siamese
    Thanks for that input.
    Did your Breeze come with an Automatic Timer?
    I'm wondering if this isn't just new product miss-communications between Technical and Marketing.
    I really have a hard time believing that they would name them almost identical then have so many differences.
    Like on one page on their web site, it says both have a full two year warranty. On another, it says only the Rapids.
    _________________
    IG Vinyl Liner 26,000 Gal / L-Shape
    Sta-Rite System 3 Cartridge 400sf
    Pentair IntelliFlo VS-3050 (3HP Variable)
    Hayward Navigator (need to replace)
    Autopilot Digital Salt System/CompuPool Cell
  4. Back To Top    #64
    May 2013
    8
    Quote Originally Posted by tcat
    And the Breeze XLS:
    Cable Length: 60'
    Never Stuck System
    2nd year limited
    Exactly.
    When I read that compared to the 4WD Breeze, for my pool it would be the same or slightly better.
    I'm a little skeptical about rotating brushes on my older Vinyl Liner pool..
    _________________
  5. Back To Top    #65
    May 2009
    Hayward, CA
    78
    is your wall 90 degree?
    definitely sounds like the motor of the rapid is stronger 210w vs the breeze 180w, maybe this will allow the rapid to go up 90 degree wall better.
    in terms of insurance, 1 year bumper to bumper, 2nd year only power supply, pump, motor.
    I'm curious about the automatic timer - is it just the shut off timer (1 hr or 2 hrs), or can we set it to run daily?
    This Warranty covers: (a), during the Initial Coverage Term, all parts of this unit, including power supplies, pumps, motors,
    electrical cables, brushes, treads, belts, bushings, handles, enclosures, bags, wheels, remote controls and other components; (b),
    during the Additional Coverage Term, the power supply, pump and motor of this unit; and (c), throughout the period this Warranty is
    in effect, defects in workmanship or materials with respect to the then-covered parts under normal conditions and normal use, with
    such use (i) in compliance with the Operator’s Manual (including without limitation the preventative maintenance described in such
    Manual) and (ii) in private residential pools in the United States of Americ
    15000 Gal Concrete IG Pool
    Hayward Max-flo XL 1HP 2 Speed Pump
    Star-Rite Posi Flow II Catridge Filter
    Aquabot 4WD Cleaner
    Hayward, CA
  6. Back To Top    #66
    I posted my experience in length about my AWD unit.
    Not only does it climbs the wall no problem but it literally tries to climb out of the dam pool. I kid you not.
    The only problem with XLS at this point is I have only heard one person write about it and it wasnt as positive and glowing as the AWD.
    you can read my review at www.doheny.com about the AWD.
    There is only 1 review and its mine.
  7. Back To Top    #67
    Also, the automatic timer is nothing more than it shuts off after 3 hours of roaming the pool.
  8. Back To Top    #68
    May 2013
    8
    Quote Originally Posted by mpk1970
    you can read my review at http://www.doheny.com about the AWD.
    But which model is the Doheny AWD, a re-badged Rapid or a Breeze?
    (Aquabot doesn't make any called a AWD, just 4WD, so it must be a re-badge)
    I asked at Doheny's, but have yet to get an answer back.
    I'm not sure exactly how you would tell, maybe by looking at the output of the Power Supply?
    Or by how many sf/hr it is rated for on the box and/or included literature?
    Thanks for any input you can provide.
    Inquiring minds want to know...
    _________________
  9. Back To Top    #69
    Quote Originally Posted by TimCar
    That I dont know but I have a belief it is both. My thoughts are both Rapids and Breeze
    Are identical despite any differences possibly shows on any site.
    Why? These are the only aquabot models built the way they are just like ecojet line.
    I dont think any difference also because Doheny also called aquabot direct to verify
    Before I bought it.
  10. Back To Top    #70
    May 2009
    Hayward, CA
    78
    cashback when you purchase in store
    http://www.aquabot.com/PageFiles/2074/2 ... _large.pdf
    Aquabot 4WD Cleaner
    Hayward, CA
  11. Back To Top    #71
    May 2009
    Hayward, CA
    78
    I can't find any video on either xls or 4wd (other than aquabot website video)...if anyone find them please share. or maybe one of you guys can make one and show us how awesome your bot is
    Aquabot 4WD Cleaner
    Hayward, CA
  12. Back To Top    #72
    May 2013
    8
    Before I bought it.
    I'm sure you are correct.
    The only difference is the Warranty is better for the BMO versions.
    I found this PDF file buried on their web site that explains it all.
    http://www.aquabot.com/PageFiles/163...%20Catalog.pdf
    The BMO versions start on Page #20
    In this catalog they have examples of what the cleaner is going to do when it hits a 90 Deg corner.
    It shows both 4WD version will climb it, both XLS versions won't.
    This is not a deal breaker for me, $250.00 difference means I'll have to scrub the vertical walls in the shallow end. (I'll have to do the stairs anyways)
    I ordered the XLS.
    It has to be better than my old Hayward Navigator...
    _________________
  13. Back To Top    #73
    May 2009
    Hayward, CA
    78
    that makes sense they are the same from the catalog. thanks for finding it.
    finally the bot cleaner search is over! hopefully this will last for 10 years...
    Before I bought it.
    I ordered the XLS.
    Aquabot 4WD Cleaner
    Hayward, CA
  14. Back To Top    #74
    tcat's Avatar
    May 2012
    Austin, TX
    720
    Thanks for finding that pdf! A few conflicts between it and their main web pages, especially about the walls and waterline. Interesting the xls cable swivels and the 4wd doesn't. Hopefully there will be more xls owners that can chime in about how well their walls are cleaned (what is "partial wall"?). Still leaning towards the Breeze xls.
    DIY chlorine feed
    BBB
  15. Back To Top    #75
    May 2013
    Millbrae, CA
    41
    Those of you who bought the XLS or 4WD, how deep are your pools? Mine has a diving board and about 8-9 ft deep at the deep end. About 22 feet long x 12 feet wide at the big end. Shallow end is much smaller. Just wondering if these 2 are underpowered for cleaning my pool or not. Pool does get a fair amount of debris from nearby trees, flowers, plants, etc.
    Pool: IG/Plaster/18k gallons/6 yrs old - Filter: Pentair Clean&Clear 320 Cartridge/120 GPM - Pump: Pentair Intelliflo Variable Speed/3hp - Cleaner: Aquabot 4wd Breeze
  16. Back To Top    #76
    Jul 2007
    Chicago, IL
    87
    I have a 20x40 IG with an 8 foot deep end. The 4WD does a fine job of making it down to the depths of the deep end and traveling up to the waterline. It does a good job overall in cleaning the pool -- I'm still very happy with it.
  17. Back To Top    #77
    May 2013
    Millbrae, CA
    41
    Nice. Then the 4wd should do nicely for me also. Care to share your purchase location and pricing? If its against rules, can you please PM me to discuss? Not many places to shop around for it online it seems other than Doheny's.
  18. Back To Top    #78
    Jul 2007
    Chicago, IL
    87
    I got mine on Amazon -- I think $799. I maybe could have got a better deal, but I'm happy nonetheless.
  19. Back To Top    #79
    May 2013
    Millbrae, CA
    41
    Alright well looks like I'm going to take a shot at the Dohenys rebadged 4wd model. Hope they are good with warranty work or claims.
    Any idea if the aquabot rebate works for the Dohenys model? Emailed Aquabot but no reply
  20. Back To Top    #80
    tcat's Avatar
    May 2012
    Austin, TX
    720
    A reply from Aquabot about XLS vs 4WD:
    "The XLS is a floor only cleaner unless there is a 60 degree or less radius from the floor to the wall. In that case it will climb, depending on the programming, close to the waterline.
    The 4WD is a floor and wall cleaner. And yes since the XLS runs solely on the pump motor it pumps more than the 4WD. Not much, but more."
    My question: What is a 60 degree radius? How many pools have 60 degree walls?
    DIY chlorine feed
    BBB
