Thread: Need help with Intex Pool over gravel
    I know this isn't ideal but I am wanting to put up a small intex pool either quick set or metal frame (probably 12'x36" pool although I would love a 15'x42").
    The issue is I only have a place very close to my house which I am sure is a bad idea or gravel to place it on. Is it possible to place something over the gravel so that I can place the pool there? Also what is the minimum distance from house that is recommended?
    Thanks so much in advance!
    Michelle
    Intex Ultra Frame 14' x 42" (3,357 gallons)
    1,000 GPH cartridge filter pump
    Taylor K2006 Complete FAS-DPD
    22,539
    Re: Need help with Intex Pool over gravel
    You can use foam sheets to lay it on. Search here for several posts discussing it. That will protect the pool bottom from the gravel unless it's very large gravel.
    Thank you Dave!
    Michelle
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    My pool had to be at least 6' from any structure and also from the property lines in order to pass city inspection.
    Your area may have different requirements.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
