Results 1 to 11 of 11
Thread: Sand filter too small?
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    I have a inground 16x32 pool with a crystal flo sand filter says model T-170BP-1 says 150lbs sand capacity. My pool is roughly 22500. Should I upgrade? Seems like the turnover is about if not exceeding 12hours
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    38,343
    Re: Sand filter too small?
    We would generally recommend at least a 4.2 sqft sand filter for your pool. So at the minimum a 27" filter.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Yeah I figured as much, should I go with hayward or pentair?
    38,343
    Personal preference ... both make good stuff.
    22,551
    I would go with whoever has the most dealers in the area. That improves your chance of them having a part in stock in case od emergency.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Star-Clear Plus Cartridge Filter 175sq
    With a 1hp pump 2 speed pump pools about 22000 gallons no water features
    That combo seem okay?
    38,343
    For cartridge filter, we would recommend a minimum of about 320 sqft, so that is much too small.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Oh wow I was just going by the chart in pumping forum.
    38,343
    We actually usually recommend double the size in the chart for cartridge and DE filters to reduce frequency of cleaning.
    Smaller would certainly work however you would have to clean more often.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Well I had to upgrade my pump and now I have a 1hp 2 speed. What would be my turnover rate with my current filter running at low speed?
    30,426
    You should have a pump curve with the documentation of the pump or the curve should be on the manufacturer's website.....that'll tell you your rough gpm.
