Results 1 to 15 of 15
Thread: LED color changing light barely glows red when turned on...
    My pool was built about 2.5 years ago. Up until recently, the pool light was working fine. It is a color changing LED light that is connected to an XPS3 X10 switch. We used to be able to push the button on the remote and the light would come on. Push the button again, and the light would turn off. However, a few weeks ago, we would push the button and the light would only come on for a few minutes and then go off and barely glow red. The amount of time that the light would stay on has gotten shorter and shorter, and now it won't turn on at all. Now, all it does is barely glow red when turned on. I contacted the manufacturer of the XPS3 X10 switch and they were surprised that it ever worked with an LED light in the first place. But, since it was working for so long, I decided to order the exact same replacement switch. I installed the replacement switch and nothing has changed. Still barely glows red when turned on. Any ideas what could be causing this? Is there a remote switch that is designed to be used with an LED pool light?
    22,553
    Re: LED color changing light barely glows red when turned on
    If you bypass the xps3 does the light work correctly?
    The xps3 is a relay switch so it should work fine. It doesn't require a load in order to operate like the dimmers do.
    That's a good question. The switch has 3 wires going into it. Line, load, and neutral. To bypass the switch, would I simply connect the line wire to the load wire? (obviously after turning off power at the breaker )
    22,553
    Correct! And that part about the breaker too!
    I will test this tonight and report back.
    Bad news. I bypassed the switch and the light only came on for a few seconds and just glows a dim red. See the pic below. Thoughts? Fried LED light? If so, do I need to drain the pool to below the light to take out the fixture?
    [center:3qjhtw6q][/center:3qjhtw6q]
    Mar 2011
    Scottsdale, AZ
    406
    What brand light is it?
    I don't know what brand it is. Is there a way to find out without taking the fixture out?
    22,553
    I can't view the pic on the "use" site but you should be able to take it out of the niche without draining the water.
    Ok, I'll pull it out tonight and take a look.
    Ok, so I finally got around to pulling the light this weekend. It is a Hayward Colorlogic 4.0. It was installed in February 2011. How long are the warranties on these things? Also, I downloaded the manual from the Hayward website, and it says that it could be a "ground fault". How would I test for that?
    [center:3ukwd41m] [/center:3ukwd41m]
    Also, how do I detach the wire? Is it removed from the pool cutout side, or from the back of the light?
    38,520
    The wires are not detachable. If it is bad (I don't know enough to say definitively), you have to pull the wire out of the conduit from the deck box (Make sure you attach a chase rope/wire before you pull it out). Then you pull the wire from the new light back through the conduit.
    Those colorlogic do not have bulbs that can be replaced ... you would need a whole new fixture.
    Replacement lights are very expensive. Does anyone know someone who can rebuild these things?
    38,520
    That is one reason I stuck with a bulb fixture.
    Apr 2014
    Western Australia
    2
    Re: LED color changing light barely glows red when turned on...
    Hi Mate, did you sort you pool light out, I'm having the same issue, any ideas
