Results 1 to 9 of 9
Thread: Advice from Intex--laughable
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Checking out their website, and came across this gem in the FAQ:
    Question
    How do you remove algae?
    Answer
    Algae will die from chlorine with concentrations as low as 0.05ppm.
    Jul 2007
    Sahuarita, AZ
    278
    Well with 0 PPM CYA, that might not be too far from the truth. I read in a recent thread that even 0.5 FC with 0 CYA is too high for normal usage.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    That's funny!! Maybe if you have one CELL of algae and catch it before it can reproduce....
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Eskimo - The intex site says 0.05, or 5 hundredths of a ppm. Your post says 0.5, or 5 tenths of a ppm!! different by a factor of 10!!
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by The Mermaid Queen
    It probably got changed in the translation between Chinese and English....what's a factor of 10 to a Chinese factory worker?
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Technical diversion for those who are interested:
    They aren't out of their minds when they say FC of 0.05 can kill algae, they are simply talking about something that is irrelivant in practice. FC of 0.05 with CYA at 0 has the same active strength as FC of 1.5 with CYA of 30. Which is to say that it can kill algae if there was any way of maintaining that level. The problem with really low levels is that they get used up almost instantly and then there is nothing left and no way to replenish the FC quickly enough. The first cell of algae would die, but if a second cell of algae fell in the pool there wouldn't be any FC left and it would do just fine.
    HEY! so I sometimes DO know what I am talking about!! 8) 8) 8)
    Dec 2007
    Central New York
    504
    Quote Originally Posted by MikeInTN
    About 5 lbs of lead.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Jan 2008
    Malaysia
    109
    It's the whole truth but the catch here is, you have to be able to maintain that 0.05ppm Chlorine without it going to 0. I suppose they do not mention how long it will take or how strong are the algae outbreak. Very misleading but I belief in it though very impractical (correct me if I'm wrong).
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
