Thread: My first Test result.
    Mar 2013
    Bangkok, THAILAND
    18
    I just got my TF-100 Test kit and this is my result.
    PH 7.4 / TC 1.2 / TA 30 / CH 150 / CYA (I still can see the black dot after empty the solution)
    I will have to add many chemical, which I will follow the "Water Balance for SWGs" in Pool School section. By the way I still have some question.
    1.I have my pool about a month with out any problem and I love to swim without smelling of chlorine. I think TC 1.2 is ideal for a pool with very low CYA, so If I add CYA and rise TC to 3.0, Will I smell the chlorine while swimming?
    2.My pool have a waterfall, SWG, So As I understand I will have to add baking soda from time to time because of that waterfall will lowering my TA, am I correct?
    -26 Cubic Meters (6,868 Gallon) On Ground Concrete pool with epoxies paint finished.
    -EMAUX FSF 400-6W Sand Filter&Pump Combo 6.48 Cubic Meters/Hour (1,711 Gallon/Hr)
    -EMAUX SSC15-T Salt Chlorinator (Cell output 15 g/hr)
    30,431
    Re: My first Test result.
    Beautiful Pool!
    No, you will not smell the chlorine much more at all. I would suggest a CYA of 30ppm to start and then keep your FC 2-4ppm at all times.
    You may need some baking soda to keep TA up but more importantly, you will need muriatic acid to keep pH around 7.4. This is more important than TA.
    With CYA in the water, we recommend a level between 70 and 80 for use with a SWG, and a higher FC level there will be less smell than there is now.
    You shouldn't let TA go below 60.
