Thread: Filter standard operating pressure and heater bypass valve.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I have a question about my Hayward micro- clear 72sq.ft. D.E. filter
    I have a 2hp pump also Hayward .
    With 2" plumbing .
    What should the Standard operating Pressure Be !!!
    And my installer installed a Heater bypass valve becuse when the Heater was first installed in 1998 it started making a loud banging sound , so he came back and installed a heater bypass valve, with it slightly closed the banging stopped.
    Also with clean D.E. the filter pressure is 15 lbs , with the bypass slightly closed .
    With the bypass open the pressure is 30 lbs (clean D.E. )
    I have not noticed the banging with it open or closed anymore ? Should i run it open or closed ???
    Does it really matter ???
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    38,290
    Re: Filter standard operating pressure and heater bypass val
    Your pressure numbers seem suspect. Are you sure you are opening/closing the bypass as you stated? I would think when the bypass is open, the pressure would be lower.
    Add a picture?
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    The bypass on only slighly opened ..
    And also i fogot to say that I have a caretaker 99. System .
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Pic
    Sean Hannon
