Thread: I may have a solution leaving the cover on, Stupid Birds
    May 2012
    New Jersey
    4
    Last year I posted about the blackbirds/crackles whatever they are dropping there offsprings waste in my pool. Well there back! like clockwork. Here is the link
    blackbirds-grackles-t44668.html
    I have my filter all setup ready to go and the pool is clean now all I have to do is uncover it if we use it and recover when done.
    The birds should be gone by late May early June. Is there anything different about the chemicals needed if the pool is covered most of the time?
    12,900 Gal. 24' X 48" ABG Vinyl Round
    Hayward Sand Filter
    Using BBB Method
    Jul 2009
    Olney, MD
    218
    Re: I may have a solution leaving the cover on, Stupid Birds
    Sure, you will find you greatly reduce chlorine consumption!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
