Results 1 to 12 of 12
Thread: Sand coming from jet
    Apr 2012
    Powder Springs, GA
    17
    Hey everyone,
    I'm still new to being a pool owner but I learned a lot from you all last season. I'm starting to implement the BBB this year and have been working to get my CYA down (wow that's not fun).
    Anyways... Last year I noticed there was sand accumulating at the steps of the shallow end of my pool where a jet comes out. It's also closest to the pump station. I didn't think much of it and continue to run the pool as normal. Half way through the season I had to replace my pump motor. The one before was a 3/4 and I put a 1.5hp and finished the season off fine.
    Now that I'm starting to open the pool I'm noticing more sand is starting to accumulate on the steps where that jet is and it's happening fairly quick. So I'm trying to figure out what's causing the problem, and what to do next before continuing to get the pool ready.
    My initial thought is that I could have a lateral(s) broken but I don't know if my pump could be the cause as well? I've lived here for almost two years and there were no disclosures as to the pool maintenance when purchasing the house so I don't know if they have been replaced before or not.
    Please let me know your thoughts, I love the forums and you all have been a great help to me already!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Sand coming from jet
    Assuming you have a sand filter.....the most likely culprit would be the multiport gasket on the top of the filter. Cheap, quick and easy to replace.
    Apr 2012
    Powder Springs, GA
    17
    Ah I forgot to mention I replaced the multi-port valve last year as well. There was sand coming through the jet before and after I replaced it. I can't imagine that the port went bad in less than a year?
    30,414
    If you are sure you are getting sand from the jets, remove the multiport and check the level of your sand....should be about 2/3 full.....no more.
    You might have success taking out an inch or so but make sure it is not overfull.
    If it's not the sand level, then you can be pretty sure you will have to empty your filter and check the integrity of the standpipe in the center (not broken or dislodged) and then check the laterals for damage where sand can be getting in.
    Smykowski's Avatar
    Sep 2011
    3,065
    I just took all the sand out of my filter looking for broken laterals because I had the same problem. Turns out the laterals weren't flattened all the way, and there was a small opening created by them not being seated. I'm pretty sure that was my problem. Not sure if yours is designed the same way, but just a thought.
    Apr 2012
    Powder Springs, GA
    17
    Thank you for the reply's. I will take apart the filter and do as suggested. Hopefully I will be able to identify the issue. Should I put any chemicals in the pool before taking apart the filter? I ask because I'm assuming it will not be running for days when I find out what parts need to be ordered and shipped.
    30,414
    It wouldn't be a bad idea to take your FC to double the normal level. If it turns out you will be down for more than a few days, you can get more chlorine in there manually.
    Apr 2012
    Powder Springs, GA
    17
    Well I have all the sand out and inspected the spine, laterals, and checked for any cracks on the surfaces and can't find anything wrong with them. I'm not sure what to take apart next?!
    Apr 2012
    Powder Springs, GA
    17
    I think I'm going to double check the multiport one more time since I have everything else taken apart right now. Any other thoughts? Thanks
    Apr 2012
    Powder Springs, GA
    17
    On another note I noticed that there is sand in the sight glass on the top of the multiport....
    Apr 2012
    Lynchburg, VA
    90
    From my experience, there it's something you are missing.
    Or, one of your laterals was angle up and as you emptied it you set it back into position.
    If you are absolutely positive there is no crack in the center pipe or on the bottom.
    And you Are absolutely sure your laterals are intact in every way put it back together and see if you fixed it.
    PF
    The Most Interesting Pool Man in The World
    I don't always have clients that want to maintain their pool,
    but when I do, I send them to troublefreepool.com!
    Apr 2012
    Powder Springs, GA
    17
    Quote Originally Posted by Pool_Fool
    PF
    I had this same thought if it was the laterals not pushed in all the way and may have pushed it down while cleaning. I hope I fixed the problem by pushing them all down, at least my filter got a good cleaning and a new setting of sand I'll update if anything changes and thanks for the help!
