Thread: Suction Line Leak Temporary Solution ?
    I live in Austin Tx and I have a leak in the suction line from my pool. I have an old(1979) pool and spa combo pool with 2 drains. The problem is a large tree root is crushing my pool lines and in the city of Austin I have to have a permit to have the tree removed which has been initially declined and could possibly take months to resolve. Does it seem logical to run a pvc line above ground to the pool to allow for the circulation of the water ?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Suction Line Leak Temporary Solution ?
    It would work, but you may have trouble with water leaking from the existing plumbing unless you plug the drains and skimmer(s). There are safety considerations with suction lines, so you need some kind of anti-entrapment cover on the end in the pool.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Look at my recent thread on using marlig fix a leak for a suction side leak. My alternative involved a jack hammer so it was worth rolling the dice which seems to be working so far
