Thread: Poolskim and Kreepy Krauly
    Shablam's Avatar
    Jul 2010
    Flower Mound, TX
    55
    Hello...
    Picked up a pool devil pro from amazon for 39.99, placed it on the end where most leaves fall and the kreepy krauly would get stuck on the fitting hooked to the return. As it would go over the hose and hang up.
    I relocated and found that I shouldn't have tried to cheap out on this technology so I am returning it and have picked up a Poolskim that should arrive next week. I really need this to be located in the first location attempted with the pool devil.
    Does anyone have any experience with these two products together (Kreepy krauly and poolskim) and keeping the Krauly from getting hung up on the poolskim.
    Just to note I have moved the weight to the end of the cleaner AND have the wall climb adjuster installed. Still the unit crawls up my wall.
    Thanks
    12,000 gallon in ground pool with rock and spa water fall, Jandy Aqualink Controls, Polaris Cleaner with booster, Hayward C17502 cartridge filter. Managed by a TF - 100 Test Kit.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Re: Poolskim and Kreepy Krauly
    I've read a few posts on the pool skim and it has pretty good reviews.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Jun 2012
    Daphne, AL
    3
    I just received my Kreepy Krauly but haven't hooked it up yet. I'll let you know how it works for me.
