Thread: new at this
    new at this
    I hane an Intex 16' AGP. We have done nothing but filled it and tested. Test results are:
    ph - 7.2
    TA - 490
    Hardness - 430
    all others were 0 due to not adding chemicals yet.
    How do i lower alka without lowering ph?
    Any links to instructions on starting a new pool? I only find on opening a pool.
    Intex vinyl 18' x 48 " AGP
    Learning the ropes so I can grow up and have my very own big kid pool! (IE -SUPER NOOB!)
    Welcome to TFP!
    No there isn't yet a sticky on pool startup. It is in the grand plan but we haven't gotten around to yet. Anyone out there what to give it a shot?
    Your TA and CH are both very high. That is going to put you at risk for calcium scaling. Usually calcium scale on a vinyl pool isn't too bad but it can mess up the pump, and heater if you have one. You can get that under control by lowering TA. There is a very through write up on how to lower TA here. Briefly you use aeration to raise the PH and then you can add acid to lower both PH and TA.
    You should start adding CYA to bring the CYA level up to between 30 and 50. Don't do it all at once, so you don't overshoot.
    The first day or two you want to add enough bleach to bring FC up to 2. As soon as the CYA starts dissolving, bring FC up to the appropriate level for the CYA level you are expecting.
    Jason, as usual, covered it all, and very well!
    all that is left to say is "Welcome to TFP!"
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    this may sound stupid but how do you airate?
    There are a number of ways to aerate, fountain, spa jets, waterfall, air compressor, aiming a return up so it breaks the surface of the water, kids splashing, rain, special fittings for a return that make it work like a spa jet, and so on.
