Thread: Chart for recommended pump and filter sizes by pool size?
    Mar 2013
    Central Iowa
    171
    I was wondering if there is a list complied on this forum somewhere of the pump and filter sizes you experts would recommend based on pool size?
    I know I have seen mentioned in individual threads that you should have a minimum size pump for X size of pool. Or "I wouldn't go any smaller then X for this size pool".
    But is this info all complied in one area? I can't find it if there is. We are considering buying a used AGP and want to make sure the pump and filter are adequately sized for the pool or if this is something we need to consider in our budget of upgrading the equipment.
    Am I making any sense? I feel like I am rambling. I guess I am looking for a quick glance area that says if you are going to purchase a 20' AGP then this is the minimum you would want for pump and filter. Or if you are going to purchase a 24' AGP then this is the minimum you would want for the pump and filter.
    OK, done rambling
    2014 Used 33'x54" Wilbar Morada,deep end approx 28,800 gal.
    Hayward S180T1580S pump/filter combo,
    Pentair Aqualuminator light/return, Aquabot S2-50
    TF-100 kit, Initial fill with pond water
    South Central Iowa
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Chart for recommended pump and filter sizes by pool size
    I don't know of a list, but you should note there are other factors in pump sizing like if you have water feature or solar hest
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,625
    Sounds like a good idea to me! But also, all same hp pumps are NOT created equal either.
    38,323
    There is a filter chart in a Pumping Station sticky, "Have you lost your head" We generally recommend double the table for cartridge and DE filters and the as listed size for sand.
    Pump sizing is more based on water flow requirements than the pool size.
    Posted from my Droid with Tapatalk ... sorry if my response is short
