Results 1 to 8 of 8
Thread: raise CYA question
    raise CYA question
    my numbers today
    FC 7.5
    ph 7.5
    ta 70
    ch 320
    cya 60
    temp 72 degrees,
    I want to raise the cya to 75 based on calcs numbers and tfp recommendations, I have natural chemistry conditioner from my neighbor liguid, active ingredients are 35% monsodium canurate monohydrate and 65% spray adjuvants, can I use this for cya increase and would I use this based on the pool cals numbers? The cals says to use 1 quart 1 cup and 5 ounces. Also can I test it again immediately if pool is circulating or do I need to wait like solids?
    roth
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    Re: raise CYA question
    Yes, you can use the liquid conditioner. It costs more, but if you already have it then you might as well use it. When using liquid conditioner, you can retest the CYA level after one hour with the pump running.
    Thanks J looking at my above numbers in florida you think I should do what I planned above or leave it alone? I did borate and it looks the best it ever has in years.
    Thanks again.
    Yes, it is worth raising CYA, especially since it is early in the swim season.
    Thanks again Jason.
    What is the highest one can safely go when the sun is hitting the pool very hard?? I live in Puerto Rico (Caribbean) right now @ 84 degrees, is 75cya the max going safely ??
    Smykowski's Avatar
    Sep 2011
    3,065
    It's less a matter of safety and more a matter of practicality. Higher CYA means higher minimum FC level for maintenance. The bigger issue is in the case of an algae bloom or other problem, shock level gets really high (21 for CYA of 75).
    You can certainly raise CYA to 80. Going higher than that starts to make things challenging.
