Thread: Epoxybond Pool Putty
    Mar 2010
    Spring, TX
    1,082
    Has anyone ever worked with this stuff and any tips or tricks. I am going to be using it to seal up some very small cracks around my returns. I would say less than half an inch long, maybe around 1/4 inch long. I tried to find some YouTube videos but no dice.
    Thanks in advance.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: Epoxybond Pool Putty
    Epoxy putty is fairly easy to work with. Be sure to kneed/mix completely. Also, keep track of the time, you want to be done before it starts to harden up. That may mean doing several small batches, instead of doing everything at once. YouTube has lots of videos on epoxy putty, most of which apply to this situation even if they aren't about pools specifically.
    Mar 2010
    Spring, TX
    1,082
    Ok the stuff was pretty easy to work with. Got the cracks covered with the stuff. From reading it seems the colder the water is the longer it may take to cure. I am not ready to swim so that is not the issue. I applied it around 1.5 hours ago and it still feels pretty soft. So maybe I should give it a day or two before I turn the pump back on. The guy that was here yesterday recommended to leave the pump off for 24 hours, so I added some extra bleach in to make sure my FC does not drop too low while the pump is off. I added it and let it circulate for about an hour before I turned pump off.
    Mar 2010
    Spring, TX
    1,082
    It seems to be working.
