Thread: Pump motor wearing out
    texasbrew's Avatar
    Aug 2007
    Humble, TX
    50
    I have a Jandy PHPU2.0 pump and the motor sounds like it is getting ready to go out. The motor is beginning to squeal. The motor was replaced under warranty several years back. I am looking to replace the motor and I am hoping that it is something that I can do myself. The motor has a tag that indicates that it is an AO Smith Cat B230SE type CX FR Y56J. I have looked at the motors on the web matching that description and they look slightly different. Is there some place that I could go that would have a list of motors that can be used with my Jandy pump? Is the motor replacement as simple as disconnection a few bolts and wires and then reattaching them? Or is this better done by a pool repairman?
    Thanks
    PG-500, WSM, 20K Gal gun pool w/ Aqua Pure 1400 SWG, flagstone coping, gray plaster, DE Filter, 400K BTU nat gas heater and Polaris 280 cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Pump motor wearing out
    Quote Originally Posted by texasbrew
    Thanks
    My pump sounded like that. I pulled the motor and impeller and took it to the pool store to price out bearings and so on. It was just a rock that got caught between the pump and the impeller. A few months later it finally crapped out. But, yes, replacing it isn't all that hard. For me, it was accessing the electrical connections - no room. I found it easier to disconnect the wires and the flex conduit at the panel and separate the wiring after the pump was out.
    I'm sure there is a cross-reference somewhere, but I don;t know where it is. Someone wlse will probably chime in soon with that info.
