Results 1 to 8 of 8
Thread: Whats the trick in cleaning out the pump filter basket?
    May 2012
    Elk Grove, CA
    60
    When the pump is running I see a bunch of junk in there (dead bugs, leaves, etc). As soon as the pump stops, it all gets sucked back up the pipe. Is there a trick to get this stuff out?
    16k gal IG pool with SWG and DiamondBrite finish
    Pentair Intelliflo pump with 520 sq ft cartridge filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Whats the trick in cleaning out the pump filter basket?
    Sounds like you have air trapped in the filter that is compressed and as soon as the pump stops, it expands and forces things back. Try bleeding air out of the filter.
    May 2012
    Elk Grove, CA
    60
    Worked like a charm- thanks!
    May 2012
    Phenix City, AL
    34
    How do you bleed air out of it? The same thing happens in our pump.
    16x32 Grecian IG vinyl pool Hayward filter swg 28000 gallons.
    30,411
    Not all filters have one, but, on those that do, there is a bleed air screw on top of the filter and you simply turn it open until water spews out.
    Apr 2011
    Warner Robins, GA
    245
    Quote Originally Posted by wyntyrose
    If your multivalve is side mounted and not on top of the filter you should see a small valve on top you can open to bleed air.
    If is a top mounted multivalve- I have no clue
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    May 2012
    Phenix City, AL
    34
    I will be spending this evening seeing if we have one. thank you!
    May 2012
    Elk Grove, CA
    60
    In my case, you turn the pressure meter at the top a quarter turn to open the valve. I had done that after cleaning the filter cartridges but I guess I closed it too early (I closed it once water started coming out).
