Thread: Solar Cover for 16' Intex
    Does anyone have a recommendation on brands? Looking to place an order this afternoon. Was hoping someone might chime in first. Thanks in advance for your help.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Solar Cover for 16' Intex
    I don't have a specific brand I like, but generally getting the thinnest is best since they tend to not last very long regardless of thickness, etc.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Amen to Linen. You'll get one full season out of it, and maybe a second, but by the third it will be crunchy and fragile and your pool and yard will be filled with little blue plastic circles.
    Thank you. I was getting ready to buy a 16mil at more than twice the price hoping it would last longer. I will go with the 8 mil.
    Orlando, FL
    690
    Quote Originally Posted by sgtcampbelld
    If you haven't bought it yet, check Craigslist. You maybe able to find a think one for less than the price of a thin one.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Thanks but I did get one already. Should be delivered today!
