Thread: Pentair MiniMax NT Won't start/work
    I have a Pentair MiniMax NT that won't work.
    The control board flashes between two displays.
    1. all these lights are on: Power, Pressure, Service, Remote, Pool, Spa, and Off.
    the display reads: 88.8
    2. These lights are on: Power and Pressure.
    the display reads ---
    the fan never comes on. I have unhooked the pressure switch and jumped the two wires and this doesn't change anything.
    I'm wondering if it is thermostat? That light never comes on?
    Any Help?
    God Speed,
    Brian
    Houston, Texas
    18000 gallon in ground pool, Cartridge Filters, 2.5 HP pump, white plaster finish. Pool built in 2005
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Pentair MiniMax NT Won't start/work
    Temp sensor.
    Get one, unplug the old one from the back of the board and then plug the new onto the board. Turn on heater. If everything runs as it should, blower comes on, unit then lights and heats, you found your problem and then install the new sensor.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    When mine gets weird, I've had good luck killing all the power at the circuit breaker for a few minutes, then turning it all back on. You might try it - it doesn't cost anything.
    dafuzz's Avatar
    Apr 2013
    North Florida
    66
    I kill the power to mine when it starts this mess as well. Sometimes 5 minutes, sometimes it takes 30 minutes. I'm going to have it professionally serviced, I'm a little weird about natural gas and electricity
    ~31k gallon 18x36 IG, Vinyl LoopLoc Sahara, Hayward C-750 75sq' Cartridge filter, Pentair Intelliflow VS3050, SGS Breeze760 SWG, Homemade Aerators, SmartPool Nitro 52 Wall Climber, TFT100 XL, Borates, and a partridge in a pear tree :)
    I had the exact same problem and I just replaced the thermastor. If you order the part online you can get it for about $35 but I needed it right away so I went to the retail pool store and it cost me double - $70. But it did work. Just shut off your filter and pumps and any electrical going to your heater. Open the front panel where the controls are located and the side panel where the water is piped into. Behind the side panel you will see the water header. There are about 4 plugs that screw into the top of it. The second one from the left should be your thermastor. It will most likely have a yellow wire attached to it. Just unscrew it, disconnect it from the front panel, install your new thermastor by adding some teflon tape and screw it in and connect it to the front panel. viola! It worked.
