Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: New home owner with pool
    I've read a ton on this site and the pool school in the past couple months. I just wanted to make sure I have a game plan before I start this project.
    This time last year, we bought a house that has a 4'x24' round vinyl liner AGP. The house was vacant for about a year (long story) before we moved in. So the pool sat without a cover for at least a year. Towards the end of summer last year I started cleaning the pool out and abandoned the whole project to be picked up this year. Well here we are and I want to get started early enough to enjoy it this summer. The water is dark green and is full of leaves, bugs, and gunk. I'll post a picture when I can.
    I have already pulled several wheel barrow loads of junk out of the pool but I'm having a hard time getting the rest not being able to see.
    I have the TF100 test kit and ran my first tests this week. I don't have all the results with me but I know CYA is 0. The water is dark but I strained it through a coffee filter and ran the test. The tube filled up and the dot was still visible.
    I plan to start shocking Monday in hopes that the water will clear enough that I can clean the rest of the gunk out. I know I need to get the CYA up, but to what level? Would I be ok with taking it to 20 or 30 to get it cleaned up and then adjust for the final result down the road?
    Also it was formerly a salt water pool, which I haven't tested for yet, but the SWG is not working so I intended to go with BBB for now. I believe this will be fine due to back washes and vacuums and water changes, correct?
    Sorry for the long post, I just want to make sure I have my information straight before I start.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: New home owner with pool
    I think that cya level would be ok to shoot for. I would go for 30 ppm on the cya. It will keep your shock level lower and use less chlorine to clear. Seems like you've got a good plan of attack.
    Just my 0.02 !!
    Jeff
    Smykowski's Avatar
    Sep 2011
    3,065
    Sounds like a good plan. I agree that CYA of 30 would be a good target.
    Please take pictures during this battle!
    38,290
    Sounds like a plan. Get the CYA up to a point where you can measure it and start the shock process. Keep fishing for gunk
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Got some liquid CYA to add to it tonight in preparation of Monday. Just to clarify, does the pool calculator work for liquid or just solid CYA? How long after adding it should I start testing the level? Should it be added to the skimmer or at the return?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Quote Originally Posted by WooleyBooger
    It works for liquid.
    Add ___ by weight or ___ by volume of stabilizer
    or add ___ of liquid stabilizer.
    http://www.poolcalculator.com/
    I'd just pour it in front of a return, so it disperses rapidly. Give it at least an hour to circulate - more is better - and don't spare the brush, that generally gets things mixed really well.
    I completely overlooked that. Wow...
    This evening:
    [attachment=0:3dbqjmsp]ImageUploadedByTapatalk1365297468.921945.jpg[/attachment:3dbqjmsp]
    Fired the pump up, got the mess off the top, and added half the recommended dose of CYA. Ill leave the pump running and check it tomorrow.
    Other test results were:
    CYA - 0
    PH - 7.5
    TA - 50
    CH - 120
    Richard320's Avatar
    Jan 2010
    19,004
    Oh boy!! Pictures!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The Loch Ness Monster might even be in there!
    Jeff
    Here's a question. I pulled the steps out of the pool last year, as you can kind of see in the pic. Is there any special cleaning I need to do to them or the hoses, pumps, net...stuff that's been in contact with the swamp?
    Richard320's Avatar
    Jan 2010
    19,004
    When you can see the bottom clearly, but are still holding FC at shock level, toss everything that has been exposed to the algae into the pool to soak a while. That will kill anything living on it.
    Smykowski's Avatar
    Sep 2011
    3,065
    I'll take the steps question:
    If you put the steps in the pool while you're shocking, there will likely not be enough circulation over the whole thing (think tiny nooks and crannys) to kill everything that might be hiding in there. Make a bleach/water solution, maybe an ounce or two per gallon of water, in a small bucket and use a rag or sponge to wipe down every surface on the steps that you can reach. After you've manually cleaned it, then let the stairs soak in the pool with everything else.
    So after adding half the recommended (pool calculator) dose to get the pool to a CYA level of 30 last night, I tested tonight and still got 0. I could tell there was a slight cloudiness to the test water, but in the tube it wasn't measurable. Does this sound right? Should I keep adding CYA?
    30,421
    Granular CYA will not show up on the test for 2-6 days.
    Meanwhile, assume the dosage you calculated is in your pool and adjust your FC accordingly
    I used liquid CYA which I thought would register on a test as soon as it as circulated.
    I added some more last night before bed. This morning its right at 30. Made a trip for bleach and i'm about to start shocking. Wish me luck!
    First hours FC check is 6, and I can already see a color change. Dosed up and more wait.
    Not sure if the pic shows it, but to me it already looks better:
    [attachment=0:yg39csz7]ImageUploadedByTapatalk1365440874.885256.jpg[/attachment:yg39csz7]
  20. Back To Top    #20
    22,550
    I can definitely see a change!
