Thread: Heat just the spa?
    Heat just the spa?
    I have an Aqualogic PS8, with a Hayward H400 heater. I messed with the PS8 to figure out if i could just heat thenspa by itself. No look, seemed likemit was trying to heat the whole pool.
    I found the menu to adjust "spa heat" but what ever i entered there also reflected on the "pool heat."
    Is it possible to just heat the spa?
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    38,521
    Re: Heat just the spa?
    You should just be able to select spa mode which should move 2 valves to only have suction and return to the spa. Not sure if you can manually turn on the heater or not. I though it could be set up to automatically heat when switched to spa mode.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jblizzle, i think you are right, i'll need to test it out this AM.
    So that was easy, pressed the "Spa" button the system switched over to spa and i adjusted the temp on the spa individually. Thanks
    38,521
