Thread: DE filter cartridge cleaner
    Our DE filter cartridge needs a cleaning before we start up the pool this year. What do you all recommend I use to clean it?
    Kelley
    Kelleyaynn
    21,000 gallon (+ or -) in-ground plaster pool with Nautilus DE filter, 1 hp pump, and Zodiac G4 automatic vacuum.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: DE filter cartridge cleaner
    Backwash it, then blast the screens with a hose nozzle. I don't even bother disassembling mine any more. I backwash until it looks clean, shut it off and let it drain out the hose, remove the lid, blast any residue off the screens with the hose, reassemble, and backwash some more to get the last of it out of the tank. Done. Maybe half an hour, and a lot of that is carefully unrolling and rerolling the backwash hose.
    There's a lot more in this thread: use-and-care-for-de-filters-t4086.html
    You might also get lucky and find a video on youtube that will show how to dismantle you filter for cleaning.
    Thanks. It's the chemical cleaning I need to do. The link you provided told me just what I needed to know.
    Kelleyaynn
