- Apr 5, 2013
- 2
I am having to add chlorine every other day and also ph increaser about every two days. What am I doing wrong? Should I be adding something I am not aware of.
I use HTH liquid Chlorine with Sodium Hypochlorite at 10% with other ingred. at 90%. I shocked it last week and still had to add the chlorine and ph increaser a few days after. I have some algae on the sides and bottom of the pool but the water is clear as can be. Please help! I'm getting frustrated besides getting expensive!
TH is 1,000
FC is 2/4
PH is 7.2
TA is 120
CYA is 100
pool is 33,000 gallons
These readings were taken about 45 minutes ago and at about 2:15 p.m. Our pool sits in direct sun except for some early evening shade on the N/W side of the pool.
My filter is a DE Model FNSP 48 with HP of 1.0
TH is 1,000
FC is 2/4
PH is 7.2
TA is 120
CYA is 100
