Results 1 to 11 of 11
Thread: Is it true I should shock my pool at least four weeks?
    Apr 2013
    Long Island, NY
    29
    Hi All! I'm new to TFP. I have a mesh safety cover over a 20x40, L shaped IG pool with a liner and live in the Northeast. Long Island to be specific. Is it true I should shock my pool at least four weeks before I plan to open? Folks also are telling me I need to add algeacide 1 week before opening. Can someone confirm if that is in fact true. I ordered one of the testing kits recommended on this site and will be testing upon receipt but was wondering if I should add water to the pool now to get it up to near skimmer level or wait until after it is opened.
    Thanks!
    40K, IG vinyl, Hayward Pro Series sand filter (S244T), Hayward chlorine feeder (CL-200), Aquabot Turbo T2 robot
    4knights's Avatar
    NE Kansas
    419
    Re: Is it true I should shock my pool at least four weeks?
    Welcome to TFP!
    Glad you ordered your kit!
    Now read pool school (top of the page) once you have read POOL SCHOOL take a break to rest your brain and read it again. This same advice was given to me and it is some of the most valuable info I have received. There is an article about shocking the pool as well.
    The knowledge you gain will help you build confidence in your ability to maintain your Trouble Free Pool.
    Even with a swamp pool it should not take four weeks to get it blue.
    Filling the pool and opening depends on your preference and water temps. I'm in central Kansas and haven't opened yet due to weather and the pool temp still being low 40s.
    If you open it now you need to maintain it to keep it crystal clear.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Welcome to TFP!
    There is no point in doing anything before you open the pool. You need to have the pool full and the pump running before you add any chemicals.
    With a mesh cover it is best to open at roughly the time the water temperature gets up to 50 degrees. Doing that will minimize the chances that you need to shock the pool at all, and shorten the time shocking takes if you do need to shock.
    Apr 2013
    Long Island, NY
    29
    Thanks. I read Pool School and it didn't answer any of my specific questions hence my posting. I lifted the cover this afternoon and took a look and I can already see what looks like green algea. The pool gets a lot of sun. My concern was that the sun coming through the mesh cover was causing more algea to grow. Loop-loc recommends shocking before opening so thought I would ask here. I will monitor the water temp, remove the cover and fill the pool when it approaches 50 degrees and take it from there. Can't wait to post my first test results so you can all advise me on how to keep that monster crystal clear!
    Aug 2010
    Dallas, TX
    4,052
    I'm not real sure I understand your question. Your title says something about shocking the pool for 4 weeks. Your first post says something about algaecide for a week.
    Either way, follow Jason's advice.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    If you have a proper test kit and you follow these directions: pool-school/shocking_your_pool you might be done in as little as a couple days. It just depends on diligence and how robust a strain of algae you have.
    Study pool school and bookmark http://www.poolcalculator.com/
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As a general rule around here we feel that algaecide is almost never needed in pool maintenance
    hawkeye's Avatar
    davenport,iowa
    118
    Rule one have a nice test kit as the two kits that are recommended on this site,without it your spinning your wheels.also if you read pool school it explains that it that how long you have to shock depends on what the water test results say when you are ready to fire pool pump up. Anything the pool store told you or sold you toss it or throw it away cause all you will need is a few simple things other than a taylor test kit is liquid chlorine.im sure the pros on this site will chime in soon to help also, hope this make some sense
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    No you don't need to shock every 4 weeks.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I remember a time at the pool store when I told the manager that I never had to shock my water. His reply was then you must have some very green water. My reply was you are welcome to come and see my green water anytime you would like.
    I like to go there sometimes to stir the pot alittle.
    Jeff
    Apr 2013
    Long Island, NY
    29
    LOL...that's funny. I made the mistake of listening to the "experts" at the pool store once. They must have seen sucker written all over my face when I walked in. Very helpful comments everyone..thanks!
