Thread: TA / pH advice
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    TA / pH advice
    Pool had some metal staining. I treated it with some Sparkle Conquest. The product worked wonders with the staining in about 30 minutes. However, my TA is now 50 and pH is 7.2.
    I have a pool heater so I'm wondering is the low pH could be problematic with the heater's copper exchanger. I'm thinking about just adding some borax to raise the pH.
    Since pH changes affect TA, do I just adjust pH and see if I need to make further adjustments for TA?
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    30,403
    Re: TA / pH advice
    That's correct but I think I would leave it right where it is. Almost all pools have a tendency to rise in pH naturally so I would simply test both parameters once a week or a bit more often and see what happens.
    A pH of 7.2 causes no harm to your heater but I wouldn't go below that
    Nov 2010
    Midland, Georgia
    353
    Re: TA / pH advice
    Thank you sir.
