Thread: Water behind Liner
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Water behind Liner
    Well I believe I have found a reputable installer for my liner. He warranties his work and carries GLI liners with the gold warranty. He will be out Saturday to give me a quote. I had a question though I just pulled the winter cover off yesterday and noticed a huge tear in the deep end which has caused the water to enter behind the liner. I'm worried it will start to deteriorate the floor. I feel a bit stuck as I cant empty pool otherwise I assume I would risk it collapsing. Should I be worried and do I have any other options?
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Nov 2011
    Moberly,MO
    1,010
    Re: Water behind Liner
    Don't worry. No longer than you are talking the floor will be okay. You will do more damage draining the pool. The pool should be stable enough tjat it won't collapse.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
