Thread: Replacement of inground vinyl liner
    Jul 2011
    Brookfield, WI
    134
    Greetings,
    We will need to replace our pool liner this year. There will also be replacement of the deep end drain and skimmers. They are all original and not to code. I have no idea what type of questions to ask or what to look for in these products, so is anyone here wiling to give me a bit of education on these items?
    Thanks. Be well
    Miriam
    20 x 44 in-ground vinyl
    Hayward Pro-Series High-rate sand filter (S310T)
    Nature2 Zodiac chlorinator
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Replacement of inground vinyl liner
    My only real advice on liners is that in my experience the so called "premium" ones can last much longer than the standard or cheap low end liners. I have bought low quality liners before that started failing (seams splitting, etc.) within 3-4 years vs. the thicker premium liner that I have now which is still in good shape with hopefully lots of life left in it that is now 8 or 9 years old.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    I've been looking around at liner brands for months. I've found that the brand GLI makes a very good liner.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
