Results 1 to 12 of 12
Thread: Why the need for acid?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok, this is one I have been wondering about for a while, what is it about swimming pool chemistry that tends to require the addition of acid to maintain pH. And more importantly why is there such a wide variation in the amount needed. I ask because my pool needs very little acid to maintain pH (around 1 quart per year of muriatic acid, although since it is so low I do tend to use dry acid instead for convenience) vs some pools that seem to need that much acid each day. My standard method of chlorinating is use of 6% bleach, plus very occasional use of dichlor when I also need to boost CYA (something under 5-10 pounds per year if I don't have a water leak). Any thoughts on why there is such variation, and is there anyone out there that uses no acid at all?
    Ike
    38,368
    Re: Why the need for acid?
    Well the pH and TA of the fill water certainly has an impact. If the TA is high, pH will rise more. If there is a lot of aeration (spa, waterfall, SWG), pH will rise more.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    I didn't use any acid at all last year, and about 1 pint the year before.
    PH drift varies dramatically with several factors, notably TA level, fill water TA level, and the amount of aeration the pool gets (which varies dramatically).
    Dec 2009
    Central Massachusetts
    2,690
    I have very low TA fill water, and keep my TA around 70 and have a chlorine generator. I havent had to add a drop of acid in 2 years. OTOH, I usually add 4-10 pounds of borax during the swim season to keep the pH from getting too low.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I too use very little acid, just a little at the beginning of last season and I was good for the year.
    I would guess as the others have said, aerating water features (waterfalls, jets, etc.), swgs, and high TA, are factors that make the the acid demand seem higher then if you only looked at pools with no swgs, low TA, no aerating features.
    I sometimes wonder if "active swimmers" (I have a lot of splashy kids constantly using my precious pool ) also can cause a significant increase? Have not noticed it here though.
    Do you have borates in your pool?
    Jun 2012
    Howell, NJ
    977
    I have never had to use acid. For the first 6 or so years, I used trichlor, so that would explain those years. However, last year, for the first few weeks, I used trichlor, and then switched to bleach. Even with the bleach, I had to use some Borax. I don't have any aerating features, and the pool is not very active, so maybe that explains it. In fact, I am going to need some baking soda and borax when I open.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have never used Borates, but my pool is indoors which changes a number of factors, lack of exposure to rain being one.
    Ike
    p.s. to add one more factor my water is from a private well
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yeah, being indoors may also decrease your evaporation rate and therefore reduce the need for make up water. Many pool owners fill water (mine included) have high TA, which of course would require more acid to counteract.
    I also fill from a private well and my TA is typically in the upper 200s . This encourages me to keep my pool covered when practical.
    Mar 2011
    Houston, Texas
    413
    I add about a quart every 10 days or so and having been doing so since the pool was about 3 months old and it's now over 2 years old. It seems to be getting a little better. My TA is around 70 and I have a SWG but not much aeration. My fill water is high in TA so it's hard to get my TA low enough to stop the pH from rising.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    My fill water TA has varied from 340 to 220 in two years. So whenever I add water, I will drive the TA up. With a spillover spa and a return on the swimout that breaks the surface constantly and worse when the water level drops just a bit, and evaporation losses from the big waterfall, my pH is always climbing. I normally consume something like 3 cups of acid at a time, twice a week I guess.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    My TA is not high but I use a LOT of acid, to the tune of about 3 gallons per month. New plaster, SWCG, and waterfalls make it happen.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mar 2007
    San Rafael, CA USA
    12,082
    Just to note that there is another option to dealing with high TA and that is to operate a "high pH" pool instead of trying to lower the pH via acid. Ben Powell wrote about this in this link at PoolSolutions. You can't do this approach if you've got metals in the water and a pool surface that can stain and you can't use this approach if your water is high in Calcium Hardness (CH). Since oftentimes high TA and high CH go together in fill water, the high pH option isn't a good one for that situation. That's why we normally don't talk about it, but for those with a high TA but low CH and no metals, it's something to consider.
    Now, that said, one can at least minimize the amount of acid by targeting a somewhat higher pH and not going down as low. As shown in this chart, there's more carbon dioxide outgassing not only at higher TA, but also at lower pH.
