Results 1 to 10 of 10
Thread: How much sun does your pool get?
    Feb 2012
    Maryland
    400
    My pool is staked out and painted waiting for excavation.
    The pool gets full sun from sun up until around 4 pm, at which time shade starts to hit the shallow end. Half the pool is in shade by 5:30ish. I will get more full sun as summer comes and the sun gets higher in the sky.
    Just curious how much others get.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    22,550
    Re: How much sun does your pool get?
    Ours gets sun about 10 hours a day during the summer, maybe more. It gets enough that it takes a good bit of cooling to keep it from feeling like bath water.
    May 2011
    Orange County, CA
    696
    Our's apparently doesn't get enough. Even during the hottest summer months (August and September), the pool still needs some heating to keep it warm enough. I estimate that during peak summer months, the pool probably gets 4-6 hours of full sunlight. After this, the trees (mostly my neighbor's) block most of the sunlight. Without any heating, the pool typically settles in the mid-70's. I will need to get a solar cover to remedy this, but definitely no risk of needing a heat pump for our pool!
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Mine gets full sun till around 4:30-5:30 (depending on location in the pool) in summer. Let me tell you by that time i'm glad to be in the shade. Last summer, my first, my pool regularly reached 94 degrees. Part of the reason is it is shallow, no deep end, the other reason (debatable) is when not in use is is covered (yes all the time). When i roll back the cover for say the first time after getting home from work the top 12" of water can be 98-99 degrees (this year i will measure temp accurately).
    I made some cool pool coolers (many threads here about the subject) that screw into my returns and spray water into the pool, the falling water feels really cold, i think i was getting close to an 8 degree temp drop (i caught the water and took it's temp).
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    techgirl's Avatar
    Vernon, BC Canada - Pool is in Maricopa AZ (currently a holiday place)
    75
    We get full sun until around 4 as well - when you're building your pool I'd suggest lots of umbrella standards built into the deck and into the tanning ledge if you have one - including our volleyball standards we have 6 and it is so great to be able to have shade but not need to hide from the pool
    Inground 12500 gallon 96 foot perimeter, 24 by 24 pool (6 by 24 of which is a "wet deck" or tanning ledge), intellibrite in spa and pool, 2 pentair LED bubblers in tanning ledge, built in table in pool, spillover spa, pebble radiance, Pentair Mastertemp 400K BTU heater, Blue Square Q360 infloor cleaner, VS2050 pump, auto leveler, Pentair easytouch 4 with wireless controller, Pentair 420 filter, custom natural gas firepit with cobalt glass.
    Jan 2011
    Richmond, Texas
    595
    Quote Originally Posted by ssgumby
    At least 10 hours if not more.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Sep 2012
    Lake Nona, Florida
    386
    We get full sun mornings, but when the sun starts to get some height our porch starts to shade the sun shelf which is in full shade at mid day (ironic eh?)
    As the afternoon progresses the porch casts a longer shadow putting the pool in full shade by mid-afternoon.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    For the first three years...from sunup till 5:30. Took down a tree end of last year so the gals could have an extra 1/2 hour or so of "full" sun. the things I do.................
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Mid morning to sunset year round.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Apr 2010
    Buckeye, AZ 85326
    619
    I'm in the 10 hrs a day range. I second the post about lots of umbrellas.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
