Results 1 to 11 of 11
Thread: Gulfstream HE 125 RA Heater PIC UPDATED 4/13/2013
    Apr 2011
    Warner Robins, GA
    245
    Hi all!,
    Anyone have one of these untis that you can comment on your experience? I am seriously leaning this direction. I like their warranty and the Titanium lifetime warranty on the heater core. in addition the COP rating is fairly high.
    Any members have this?
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Apr 2011
    Warner Robins, GA
    245
    Re: Gulfstream HE 125 RA Heater
    Ok Update: I ordered the Gulfstream HE 125 TA heat and cooling unit. It came down to Gulfstream and Aquacal- Both have Titanium heater Exchangers. Both are AHRI certified for BTU performance. After that it was the cost factor. I should have it in a couple weeks.
    I will keep you all posted and informed!
    Apr 2011
    Warner Robins, GA
    245
    Update: Trucking company called- heater is to be delivered tomorrow. I ran the electrical this weekend and poured a new slab as my existing was too small. Hopefully this weekend is the install. Photos soon!
    Apr 2011
    Warner Robins, GA
    245
    Re: Gulfstream HE 125 RA Heater PICS UPDATED 4/13/2013
    Ok So I plumbed and wired this beast today- I still have to put the remote control wiring in from the Aqua Plus, but for now its running on its own sensors. I still have to trim some wire ties and other small odds and ends but over all it came out well. It all sits behind a brick wall that serves as my pool mechanical area. (Ya I got a bit crazy with the purple primer- Don't laugh - hehehehe. I'm going to paint the plumbing to match the stone)
    I also upsized all the plumbing to 2".
    Next step Aqua Plus integration.
    Thanks to you all for the help! A bring thanks to Harleysilo and Mas985!!!!
    Re: Gulfstream HE 125 RA Heater PIC UPDATED 4/13/2013
    I am considering the Gulfstream HE125RA for my pool - would you provide an update on your experience with your heater? Thank you!
    Apr 2011
    Warner Robins, GA
    245
    Asch been a while since I've been on the forums. The heater works great no problems. Heats well. I am very satisfied.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Mind me asking where you bought it? I am thinking of getting the HE90RA. All seem to have a smaller footprint that most others, and specs are just as good or better. 2 year full warranty is nice too.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Quote Originally Posted by jhalpinjr View Post
    Hi,
    Hopefully you'll still get this and it will alert you email, but I'm looking to buy a Gulfstream HE 150 RA this week. Can you please give a update how your is working and if you've had any issue and if so if it cost you anything? Also would you buy again and how well it does with yhour pool.
    Thanks!
    20,000 gallon free form plaster pool built in 2001. Pentair Intelliflo pump, Pentair Quad 80 DE Filter, Pentair 40k gallon salt chlorinator, Pentair Easy Touch 8 control panel, Fafco Solar water heater with 7 (4'x12') panels.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I bought the 110ra and love it. Been running since May 1st, set at 87 degrees. My 2 speed pump runs from 11am to 7pm, on high from 11:30 to 1:30. Pool is at 87 by 1 every day and hp shuts off rest of day. My ee bills are lower this year than last (mainly because I also installed a more efficient heat pump for the house). No solar cover all summer. Second best thing I bought for the pool! (1st is 4wd Breeze). Although Stenner pump is also up there in "can't live without" area.
    DIY chlorine feed
    BBB
    NJ
    291
    I know this is an old thread but wonder if after having the Gulfstream for a while you are still happy. I am considering one or an Aquacal.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Turned it on Wednesday, pool was at 85 for the weekend. Runs great, so far no issues. Heats at 1/2 degrees per hour. Haven't noticed any effect on my electric bill. Do use a solar cover until about June.
    DIY chlorine feed
    BBB
