Thread: Different Kinds of Acid?
    On poolcalculator.com
    Its shows different kinds of acid. For example 15.7% 10 degree Baume or 31.45% - 20 degree baume
    What does this mean? Are these different types you can buy?
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Different Kinds of Acid?
    Quote Originally Posted by phoenixtx
    It's just how diluted they are. Generally, the half strength stuff doesn't cost half as much, so the stronger is a better buy. The weaker stuff is usually marketed as "fumeless" or something. When you buy acid, see what it says on the box or jug. Then you can pick the right one for the calculator to use.
    ah okay, thanks for the heads up
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    My preference is for the 15.70% product. Where I'm at, it's the identical net price compared to the 31.45% product, but I find it less scary to handle (almost no acrid fumes) and after what I've been through experiencing the delicacy of my colored plaster, pouring less aggressive chemicals into my pool has become a high priority. An accidental spill on my concrete deck may be less damaging too. Obviously on the other hand it takes up more room and creates more waste containers. I buy pool specific 15.70% Kem-tek brand from the Home Depot garden department but the more expensive paint department version is called "Safer" muriatic acid because of its reduced strength.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
