Thread: How soon to seal stamped concrete
    Our concrete contractor wants to pour and stamp our concrete and then come back the next day and seal. I think this is way too soon since the concrete is still curing. I know they want to do the saw cuts the following day also, which is fine with me.
    Anyone have any thoughts? I know that most people recommend a sealer that has 20% or less solids in it.
    Nov 2011
    Moberly,MO
    1,010
    Re: How soon to seal stamped concrete
    Any concrete contractors that have poured stamped decks in my area seal the next day. They also recommend sealing it once a year.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    4knights's Avatar
    NE Kansas
    419
    Depends on the pour and your area. Check out this site http://www.concretenetwork.com/
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    I'm located in southern New Jersey. I'm familiar with that website.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    My last stamped concrete deck was saw cut and sealed the following day.
    A second coat of sealer was applied a week later.
    The first coat got consumed by the new concrete almost entirely.
    Try to negotiate 2 coats of sealer if you can.
    A non-slip additive will help keep the little ones from slipping on the sealed stamped concrete too.
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
