Results 1 to 11 of 11
Thread: Intellipro flow rates
    I saw an old post with a link to a spreadsheet that enabled you to calculate gpm from rpm and watts for an intellipro vs pump. Could anyone tell me where I could find this type of spreadsheet? Or how to generate one mathematically. The link was no longer good. I just had a intellipro installed and that seemed like an easy way to estimate gpm.
    I can read the filter psi on the return side but don't know what the head loss on the suction side is so I can't really use the charts that plot head loss, speed and rpm...
    Thanks... First pool I have owned....
    JimboAZ's Avatar
    Oct 2012
    Maricopa, AZ
    103
    Re: Intellipro flow rates
    Not sure about the spreadsheet but this thread has some inflo on flow rates has-anyone-hooked-a-flow-meter-to-a-pool-with-an-intelliflo-t55960.html. If you search for 'spreadsheet' maybe you can find something?
    --22k gallon pool/spa, IG, pebble w/ glass beads/abalone, all tile spa w/ stacked stone and spillway, 30 sf waterfall, 3 telescopic fountains, EZ Touch 8
    --Pentair VS3050, Whisperflo waterfall pump, Clean & Clear 520 cartridge filter, Intellibrite 5G LED lights, Ozone, Q360 in-floor cleaning, 400k btu heater
    --100 perim ft pool, 25 perim ft spa, Depth 3.5' to 7', 405 sq ft travertine decking, TF100 test kit
    --Time Lapse Video of our Pool Build ---- Our Pool Build Thread
    Thanks for that link. It was very informative for me....
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can also find some spreadsheets on the web site in my signature: Energy Efficient Pools
    Mark
    Thanks Mark. I found the exact spreadsheet I was looking for.. I appreciate your reply.
    Ted
    Hi Mark...
    I hooked a vac guage to the intellipro pump and set the speed for 3110 (cause it was one of the flow rate curves in the manual). Filter is new. I had a reading of 1786w directly from the pump software. This correlates to about 70 gpm from your chart.
    The pump psi was 20. Using the formulas found in the forum (2.31 for psi to head, and 1.13 from hg to head) I calculated about a 57 ft head pressure. At 3110 rpm on the chart in the manual, this correlates to around 90 gpm! I don't expect the numbers to lay on top of each other but that's quite a difference. Which is more likely correct? Any flaw you see in my measurements?
    Just trying to understand how the system is performing!
    Thanks
    Ted
    I have a 9000 gallon kidney shaped in ground pool 5'6" deep with everything (pump etc.) pretty much flat with respect to lay of the land. Also have two drains and a skimmer active all with 2 inch pipe.
    There are two different pressures, the pressure reading from the filter pressure gauge and the pressure reading from the vacuum gauge. We need to know both of those numbers. I am assuming that 20 psi was measured at the pump with the vacuum gauge. What was the pressure at the filter?
    Sorry I wasn't clear. The 20 psi was the pressure on the filter guage and the vacuum guage on the pump was 7 hg.
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Converting RPM & Watts to GPM is usually far less accurate than converting PSI/inHG to GPM. So I would trust the head measurements over the wattage measurements. However, you may need to adjust for the plumbing between the pump and filter. The Operation Point spreadsheet allows you to do that. My guess is that you have a backwash valve?
    Mark
    Thanks Mark.. I'll go Ahead and use the head measurements. I have a cartridge filter and no back wash valve. I assume I can use the proportional equation new gpm= old gpm*[new rpm/old rpm] to calculate gpm for speeds not plotted on the graph. I measured head at 1500 rpm as well as 3110 and read the gpms off the graph and then calculated one off the other and the math seems to work... I'm not trying to be super precise, but just want to make sure I am getting right proper flow both for filtration and optimal performance of the new solar system I just had installed. All the measurements I have taken so far were with the solar off...
    Thanks again for your prompt response...
    Ted
    mas985's Avatar
    Pleasanton, CA
    11,737
    In that case, I would stick with the head measurements. And yes, you can scale by RPM ratio.
    Mark
