Thread: Concrete pool deck sealer
    I am planning on sealing my pool deck. I just finished my pool this time last year. We shouldve had the deck sealed because we really like the dark wet look when the concrete is wet. when its not wet it looks light and dull. my question is has anyone ever used DECK-O-GRIP W/B Slip-Resistant Concrete Deck Sealer. it says it leaves it with the wet look as well as adds slip protection. The concrete is stamped. Should it be rolled on or sprayed on. Also how many coats should I apply? Also could i use the same product on the coping? Thanks.
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
    Karmann's Avatar
    Apr 2012
    DFW Texas (Midlothian)
    123
    Re: Concrete pool deck sealer
    i have used it on my patio and love the stuff. I rolled on one coat
    It does wear over time and prob should be applied at least once a year to stay looking fresh imo
    before deck-o-grip
    after deck-o-grip
    Martin,
    Midlothian, TX
    Pool built in August 2012, 17.2k gallons, IG Gunite/PebbleTec (Midnight Blue), 1k sq ft Washed Aggregate decking, Jandy Stealth 2HP Pump shared with Spa, Aqua-Pure Salt-Gen, Jandy 1.5hp wtr feat pump, Jandy CV580 Cart Filter, Jandy AE3000TR Heat Pump w Chiller, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Jandy Pool (2) and Spa (1) Multi LEDs, 2 Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl 3' sheer descents and spa spillway
    Click Here For My Pool Build Thread
