Thread: Glue for solar cover? Flexible and durable?
    Jan 2010
    Northern Virginia
    282
    My solar cover is in 3 pieces. Two are huge (about half the size of the pool) and one is very small. I'd like to glue the small piece onto one of the big ones for ease of use (duct tape did not work).
    Has anyone done this before?
    Is there a good epoxy out there that will do the trick?
    I was hoping for something strong and flexible, but was also wondering if inflexible would also work so long as I made many small spots instead of one long seam.
    Anyone have any thoughts?
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Glue for solar cover? Flexible and durable?
    I don't think glue is the best route. What I would do is attach the pieces with solar cover fasteners for example https://www.google.com/search?q=FG-pfs& ... 0&bih=1075
    If you are still looking for a glue I would try HH-66 or PoolTak spray adhesive
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Apr 2010
    Buckeye, AZ 85326
    619
    Could you do it with a hot iron?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    I would try Amazing GOOP® Household, it is both waterproof and flexible and it is also easy to work with.
    It takes extremely good temperature regulation to heat seal plastic, I very much doubt you could do so with a regular iron.
