Thread: Getting Cold (briefly)
    I found a few old threads on cold temps after opening pool and I am pretty sure i am safe but, just making sure. I opened over this past weekend and water temp is 52. Expect temps to bottom in the mid 20's tonight and tomorrow night (daytime temps around 50). I will be running the pump 24/7 anyway until clear.
    As lonmg as i am running, no worries about cold correct?
    Also, i have an accessory pump for a water feature (stone waterfall) and can keep it running as well but, would it also be safe to simply open the pump's hopper and allow the pipes to drain down to the pool water level? The feature pump does not run through the filter and has no shut off valves just a switch to turn the pump on or off.
    THX!
    30,000 gal vinyl lined
    spill over spa
    waterfall w/dedicated pump
    AquaHeat Heat Pump
    3 year disciple of BBB
    Mar 2013
    Sayville, NY
    53
    Re: Getting Cold (briefly)
    Went into the upper 20s here last night and I just left the pump running overnight. No problems this morning. Supposed to be the same for the next 2 nights. Hoping for the best myself.
    16 x 32 Vinyl IGP ~22000 G
    thx!
    spill over spa
    AquaHeat Heat Pump
    38,245
    Yup. Just keep the water moving and you should not have any problems.
