Thread: Please help me identify spa jet inserts
    Hello,
    I bought a home with a gunnite pool and spa. The spa has jet inserts that I can't seem to locate for replacement.
    You can see in the attached figure this is a snap-in / press-in fitting with threads on the inside that receive an eyeball nozel that is held in by a threaded retaining ring with two barbs on it.
    I am at a total loss to identify this and would appreciate any help so that I can get replacements for broken ones.
    Thank you.
    JimboAZ's Avatar
    Oct 2012
    Maricopa, AZ
    103
    Re: Please help me identify spa jet inserts
    Not sure but maybe someone who specializes in those can help you. Like these guys:
    http://www.spadepot.com/shop/Jet-Wall-F ... -C695.aspx
    http://www.spadepot.com/shop/Eyeballs-R ... -C697.aspx
    --22k gallon pool/spa, IG, pebble w/ glass beads/abalone, all tile spa w/ stacked stone and spillway, 30 sf waterfall, 3 telescopic fountains, EZ Touch 8
    --Pentair VS3050, Whisperflo waterfall pump, Clean & Clear 520 cartridge filter, Intellibrite 5G LED lights, Ozone, Q360 in-floor cleaning, 400k btu heater
    --100 perim ft pool, 25 perim ft spa, Depth 3.5' to 7', 405 sq ft travertine decking, TF100 test kit
    --Time Lapse Video of our Pool Build ---- Our Pool Build Thread
