Thread: DE In my pool
    Mar 2013
    Houston Texas
    2
    DE In my pool
    I'm a new pool owner and blew my multiport gasket and covered the bottom of my pool with DE (I did this turning on the pump while the system was closed). I went and bought a new gasket and installed it and noticed that my handle was loose (limp). after completing the installation I added DE and again it went all over the pool. After looking on the internet I decided to replace the spring below the handle... the new spring makes it a little tighter but it is still loose and the filter still sprays DE all over the place when I add it to the skimmer.
    I'm at the end of my rope with this thing... If anyone can help I would really appreciate it!
    30K gal, IG Plaster, 1-1/2 HP Pump, 60 sqft DE filter - Hayward 6000
    22,550
    Re: DE In my pool
    Welcome to TFP.
    My bet would be that you either didn't get the gasket placed correctly or the valve top is out of alignment with the bottom of the valve.
    Can you post pics of the valve?
    What model filter do you have?
    Mar 2013
    Houston Texas
    2
    Re: DE In my pool
    Ill take some pictures when I get home this evening... As for the Filter model I have a Hayward DE6000 Micro-Clear Filter.
    ... Its funny.... I thought I did everything right. The gasket fit right in the grooves.
    I would like to mention that when I replaced the spring the plastic shaft the spring goes around was very stuck in the valve cover. I had to tap it out with a hammer... could this snugness keep the spring from doing its job?
    22,550
    Re: DE In my pool
    It certainly could. You may to need to replace the shaft o-ring if you haven't already.
