Ya that probably was a stupid question on my part. Well you were right, the shaft was very rusty. At first I couldn't hand turn it plus the capacitor and other things were in the way, so I unbolted them and lightly tapped on the shaft to get it moving. It finally broke free, and I added a little multi-purpose lubrication. So I put everything back together and the pump works!
However I can't get the system to prime. My steps were as followed.
I am currently coming from a winterized pool.
1. Open pump lid and insert basket.
2. Screwed on sand filter cap on the bottom.
3. Turn filter to 'Filter'.
4. Made sure valve to main drain was open.
5. Fill basket to the top with water, then hand tighten lid.
6. Turned on pump.
7. Repeated steps 5 & 6 multiple times.
I then proceeded to evaluate the condition of the sand filter.
1. Unscrewed all pipes to sand filter.
2. Then repeated steps 5 & 6 and the pump did shoot water out, so the filter is getting water.
3. Accessed the sand in the filter. (It looks pretty good. The filter is filled with sand about 3/4 of the way.
There is also a pressure gauge that I attached, and the pressure never moves off of 0.
Any thoughts? The sand filter probably hasn't been ran in awhile. Also it is possible that the main drain could be blocked.. I been scrapping gunk off the bottom.
Ill try again tomorrow, and Ill attempt to clean the bottom even more.
Thanks again,
Brandon
