Thread: Can Low Borate Levels Help Algae to Grow.
    Aug 2008
    Honolulu
    429
    I think I read this somewhere. If say the level is only 8 ppm is this an issue and if so why?
    Thank you.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    38,475
    Re: Can Low Borate Levels Help Algae to Grow.
    If so, then I am doomed because I have 0ppm of borates
    Or are you suggesting that 0ppm is fine and 30-50ppm is fine, but somewhere in the middle would help algae? I do not see how that would make any sense.
    Aug 2008
    Honolulu
    429
    Obviously 0ppm is fine and 30-50ppm is fine, but I believe I read low levels can help algae to grow presumably low is say 5 -15. or 20.
    Mar 2007
    San Rafael, CA USA
    12,082
    Boron is an essential micronutrient for plants including algae, but the amount needed varies by species. As noted in this link, green algae had no effect between 10-24 ppm. Table 18 shows toxicity levels for algae which results in growth inhibition for of 50% at levels of 34-52 ppm and approaches 90-100% inhibition at around 100 ppm.
    Nevertheless, I would not say that low levels of boron in a pool accelerate algae growth unless you compare such growth against algae in water with no boron at all. Phosphate levels are usually the limiting micronutrient in most pools. Of course in your pool with extremely high phosphate levels, algae growth would be limited only by sunlight and temperature were it not for chlorine properly managed relative to the CYA level.
    Aug 2008
    Honolulu
    429
    chem geek,
    Thank you for the reply. It seems therefore that if, and only if, the Chlorine and CyA levels are properly maintained there are no issues.
