Thread: Photo of cool water entering warmer hot tub
    First off I'd like to echo the sentiments of many people here with a huge thank you to the very knowledgable contributors on this site! Without you all, I would be at a complete loss as to how to maintain my pool, and I'm sure the photo below would not have been possible.
    Perhaps this is 'ho, hum' to others, but I thought it was kind of interesting when I noticed the shadow of the cooler 70* water entering the warmer 95* water of the hot tub yesterday. The water depth is about 18" to the ledge where the shadow is and quite honestly I am very pleased with it's clarity! I will have to leave the 'hows and whys' this happens to those much more knowledgable than I, but I don't imagine it's too much different than heat waves coming off hot pavement. Never thought it would make a shadow however. I do have borates at 50ppm and that does some interesting things to the water........reminds me of the 70's in some ways.
    11K In ground, plaster with spillover spa.
    Pentair IntelliFlo VS pump. Easytouch control with wired EasyTouch 8 remote and Screenlogic2 Interface.
    Pentair 250K Mastertemp Heater. All important TF100 test kit.
    SW Florida
    38,397
    Re: Photo of cool water entering warmer hot tub
    I see the same effect (with opposite temperatures) when my solar kicks on in the mornings. That is some HOT water entering the pool initially.
    4knights's Avatar
    NE Kansas
    419
    It's much like the effect you see & feel while scuba diving as you pass through the thermocline (Abrupt change of temperature in water)
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Aug 2011
    Virginia Beach
    295
    If I had to guess, I'd say the different temperature waters are at different densities, and therefore don't mix very well? I've seen a photo of this phenomena where 2 rivers converge but the waters won't mix. It was on River Monsters, if I recall correctly.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Temperature affects the refractive index of materials...you get a similar effect dissolving sugar in tea, or salt in pool water, whatever.
    38,397
    Or the most obvious ... pouring bleach or acid in front of the return.
