Results 1 to 8 of 8
Thread: How often does the salt cell need to be replaced
    How often does the salt cell need to be replaced on the CompuPool CPSC36?
    How about other chlorinators?
    27K gallon vinyl in ground pool, sand filter
    Re: How often does the salt cell need to be replaced
    It is difficult to predict how long a cell will last on a specific pool. It has a great deal to do with the relative size of the pool and the SWG. Larger SWGs will last longer than smaller ones when used on the same sized pool. Typically a cell lasts three to five years, but it can vary from that by quite a bit.
    All of the above applies to most brands.
    So would you expect the cell to last 3-5 years on a CompuPool CPSC36? I'm trying to decide which SWG to go with. My pool is a 26k IGP with a liner.
    Aug 2010
    Dallas, TX
    4,052
    That is the expectation for all brands.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just be aware premature failure is a real possibility on all of them, there was just a message here over the weekend with someone commenting that they are now on their 3rd cell in 3 years..
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I believe most cells are rated on 10000 hours at 100%, but many factors come to play. 3-5 years is a good estimate.
    38,271
    Quote Originally Posted by jfoscue
    We generally recommend sizing the cell for 1.5-3 times your pool size. So that 36 might be slightly on the smaller side (interesting that the Australian brochure lists this for 120,000 liters = ~32k gallons, but the US stores state up to a 40k gallon pool looks like it must be a slightly different design offered here).
    A larger unit will cost a little more, but should last longer as the cell will not require as much run time ... hard to say definitively if the larger one would last longer enough to offset the higher cost, but it seems too.
    Aug 2011
    Clarks Summit,Pa.
    37
    I only have my SWG for 2 years but I found out the best thing to do is read pool school
    and Pool Water Chemistry, I purchased the TFT-100 test kit and that is the best thing
    I have done,it is not hard to keep your pool balanced once you get it there.if you let the pool get way off it
    can cause you many problems that you can avoid and save money.
    12,000 gal. 14x28 Inground vinyl liner (2004), 1 HP. Jacuzzi magnum pump,
    Raypak heater, Jacuzzi laser sand filter,Autopilot DIG-220 SWG, 35/22 cell,
    TF-100 test kit,K-1766 saltwater test kit, speedstir
