Thread: Please review before I order
    Feb 2013
    Nashville, TN
    49
    As my finger hovered above the "click to order" button I decided I would feel better if I got one final approval from you guys first.
    Here's what I'm about to order:
    28' Sharkline Matrix AGP
    Pentair SD80 sand filter
    Pentair Optiflo 1HP/2spd pump
    Pentair Intellichlor IC40 salt system
    25gauge uni-bead liner
    Am I good to go?
    Sharkline Matrix 28', Pentair SD80 sand filter, Pentair Optiflo 1hp/2spd pump, Intellichlor ic40 (installed 7/2013)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Please review before I order
    Those choices look good to me. I am assuming since you are ordering the unibead liner, you are not going to have a deep end?
    Other stuff that you may want to consider at some point are foam coves and a pad (for underneath to protect against nut grass and roots).
    Feb 2013
    Nashville, TN
    49
    Correct, no deep end. I am going to order a Gorilla Pad. What is the advantage of the foam cove?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Foam cove forms the cove (corner between wall and bottom) instead of using sand. Are you installing, or are you having an installer do it? If you are having someone do it, then check with them to see what they need/want. If you are installing it, you might want to consider polystyrene foam insulation on the bottom like I did. Makes for a nice bottom and is extra protection against rocks etc. I have read that it does not work for nut grass (not a problem for me).
    Sep 2012
    Gardiner, ME
    165
    My pool builder wanted Foam Coving, asked him about sand cove he said and I quote "I can do either one, but the end result will be better with foam"
    Asked him about the foam on the bottom and walls his response was "naw, if you use a good sand that packs really tight you wont need it"
    24 ft Sharkline Matrix AG
    Waterway 1HP 2SPD Sand Filter 100lb sand capacity, using 50lb of ZeoSand
    TAYLOR K-2006 test kit.
    Installed Spring 2013
    16x16 Deck Going up Soon.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    You only need gorilla pad if you have a concern about poking and tearing liner from underneath (nut grass, rocks/glass, etc), if not then don't waste your money, there is absoutely no cushion to gorilla pad, I have it under my pool.
    PS, it's not foam, it's a geotextile fabric about 1/16" thick.
