Thread: air in solar heater
    air in solar heater
    Quick question about a solar heater.
    I have a solar heater hooked up in line to my pool with an automatic valve that opens or closes based on temperature. Water goes from the pump to the cartridge filter, then either through the heater to the SWG or directly to the SWG, then to the pool. I also have a Polaris installed.
    Every time the solar heater kicks on a tremendous amount of air comes out of the pool jets. I have never seen an obvious leak, and have had it serviced, but the air seems odd. Since it is a closed system on the pressure side I am not sure how air gets into the system. Is this normal for solar heaters? Is this anything I need to be concerned about?
    TIA
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: air in solar heater
    Your solar panel should have a vacuum breaker, probably on the high side opposite the outlet, that lets air in when the panels are shut off. This is to keep the panel from overheating when the water is static, and it is normal to have the bubbles as the panel fills with water.
    38,262
    Yup. Sounds normal since with a proper install the panels should drain when the pump turns off.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Thanks for the replies and makes sense to me.
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
