Results 1 to 16 of 16
Thread: Pool Filler With Pictures
    Mar 2013
    Mississippi
    10
    Little Project over the weekend. I'm constantly overfilling my pool. This will be used when I'm at home to make sure there isn't any mechanical failures. Cost about 30 dollars with me having the plumber's putty. I got this idea from Instructables.
    http://i1279.photobucket.com/albums/y53 ... 1364786057
    http://i1279.photobucket.com/albums/y53 ... 1364786603
    http://i1279.photobucket.com/albums/y53 ... 1364786581
    Thanks so much, this site has helped me more than I can say.
    Tim Hall
    24' X 54" Sharkline Matrix Resin AGP, Aquabot S2-50, TF100 test kit
    30,419
    Re: Pool Filler
    Very nice!
    Mar 2013
    Mississippi
    10
    Re: Pool Filler With Pictures
    Thanks Dave, Thank You for all your help getting going this season.
    Tim Hall
    38,275
    Kudos!!! That is a nice above ground auto-fill you put together there.
    Mar 2013
    Mississippi
    10
    Thank You very much,
    Tim Hall
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job thall. I like. Instructables has some cool stuff.
    Jeff
    Apr 2010
    Buckeye, AZ 85326
    619
    Thats pretty cool. PVC is almost as versatile as dust tape.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    22,548
    That was pretty good. I have the same problem of forgetting to turn the water off when refilling so I'll be makin me one of those.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I like it . Looks like another item for the ToDo list
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Mar 2013
    Mississippi
    10
    Simple project, what i changed from the instructables is to use a 90 degree fitting 1/2"x 3/4", with the 3/4" side threaded attached to the valve. That is where I also used the epoxy putty.
    Tim Hall
    Jul 2011
    Kenilworth, NJ
    12
    here is a device you can buy that will work too
    http://hudsonvalve.com/index.html
    Intex 16' x 48" Ultra Frame
    Intex 2650 GPH Sand Filter
    Intex Krystal Clear Saltwater System CS8110
    Mar 2013
    Mississippi
    10
    Looks like that would be a good alternative.
    Tim Hall
    Jun 2012
    Louisiana
    47
    I built one of those for my IG pool last year and it has worked like a charm. I spent a fair amount of time looking for an adapter to go from the NPT thread to the toilet fill thread to find that it is basically a proprietary thread and no crossovers were to be found; that's where the putty comes in. The threads from the 3/4" FNPT are close enough to "hold" the two together in order to place the putty to hold it together.
    The best part is that it will only cost ~$10 and 5 minutes to replace if/when it ever fails. Much better and cheaper than the $80 pool filler that only lasts about 2 seasons of use.
    Hardest part of the project....setting the water level!!!
    25,000 gal Plaster; Hayward 1 hp Super II; Hayward Vari-Flo XL Filter
    Mar 2013
    Mississippi
    10
    The pool filler has been working quite well. I have moved it to a few locations around my pool to find the best location. Such a simple project i should have done years ago. No more dragging a hose out to the pool and trying to time it so the pool would not overflow. Highly recommend as a small project.
    Tim Hall
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Ingenious!!!
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Mar 2013
    Mississippi
    10
    Here is the link if anybody is interested in possibly building one for yourself.
    http://www.instructables.com/id/Automat ... er-Filler/
    Tim Hall
