Thread: Pump Problem
    Pump Problem
    Hey guys, I am new to the board and fairly new pool owner. I recently got a used pool and pump. I believe that my pump is going out. I have a leak in the pressure gauge at this time which I am waiting on the part to fix, however yesterday when i turned the pool motor on I didn't hear any sounds but the motor is sluggish on the low setting and kicks breaker almost instantly on the high speed. I have several questions. Would the broken pressure gauge cause the motor to do this? I have a 30ft 52in deep AGP. If new motor needed, Currently I have a 2.0hp motor with 1 1/2in PVC and maybe 10ft of head at most. Is the 2.0hp too much? What would you suggest? Also what pumps are the best for the best price. I know this is a lot of questions but I am desperately needing help. We just built a new deck and really want the family to enjoy the pool this year.
    38,275
    Re: Pump Problem
    Without any high flow rate features, 2 hp is way more than you need. A 3/4 or 1 hp 2 speed pump would likely be fine and cheaper both to buy and run.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Problem
    Quote Originally Posted by bryanemtp
    No but a motor with a bad bearing could.
    Very unlikely that you would have only 10' of head with a 2 HP pump. Probably in the range of 50-60' of head depending on the pump model and plumbing layout. What is the filter pressure?
    Ditto to what Jason said.
    Mark
