Can anyone ID my Hayward Vari-Flow?
May 24, 2012
25
Auburn, AL
( I moved this to the proper forum and deleted the original - sorry for the oversight )
Hey Everyone,
I have a vari-flow valve and it's a bit leaky at the sight glass and needs a new pressure gauge.
I've looked closely for the model number but it seems to have faded and/or worn off. Can anyone ID it?
A very high res photo is here: http://imgur.com/50qyYBz
Thanks!
That pic is a little too close but I'm pretty sure that's a SP0715.
If it's just the sight glass o-ring and the pressure gauge, you can use a generic o-ring that can be found at most home improvement stores and the pressure gauge is generic as well. You just need a 1/8" npt bottom mount. There's an active thread about cheap filled gauges, if you're interested in that. I'd get a 0-30 psi unless you know that your pressure runs higher than that.
