Thread: DE in a Pentair filter cartridge
    Sep 2011
    Miami Beach, FL
    125
    I was bored and read (yes, really) the manual for my filter. It said to add 0.5 pounds of DE for each 100 sq ft of cartridge surface...
    really?
    I never knew this....
    Comments?
    32000 gallon, inground, fiberglass, Aqua-Rite SWG, Pentair 420 sqft cartridge filter (Installed-ya baby), Hayward Super II pump 1.5 hp, 144k BTU heat pump, Dolphin Dx5 Plus, and a good test kit from Duraleigh!
    Re: DE in a Pentair filter cartridge
    You can if you want, it doesn't make a huge difference. If you do add DE, make sure to only do so once and to only add the amount they specify.
    I do use synthetic DE..ie; Filter Helper in my pool. It does help mine with the fine stuff and does make the filter a bit easier to clean. Just my experience and my humble $.02...Good Luck!!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Filter helper is a completely different situation than DE. DE will embed into the filter fabric and never come out. Filter helper will rinse off when the cartridge is cleaned.
    Thanks Jason, I should have added that to my post to explain rather than just describe. Yep, the synthetic does rinse off very easily..Hope that helped Mk1....
